Date/Time: Mon, 25 Nov 2024 09:42:09 +0000
Alerts
View Count: 1174
[2014-01-27 17:58:46] |
Discount - Posts: 73 |
I have a bunch of different futures chart books with the CCI indicator on them, and alerts set on all the different futures CCI, with different alert sounds on them all. The chart books that are open on my desktop are the only alerts that should go off correct? So if the chart book is closed, those CCI alerts should not be triggering? Also, on the alerts tab, is I do not have any of the little box's checked, will the alert still trigger?
[2014-01-27 18:29:00] |
Yes. The alert will still trigger as long if there is an Alert Condition Formula specified for the study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-27 18:30:18] |
Even if the chart books are closed? And not on my desktop?
[2014-01-27 18:49:49] |
If the Chartbook is closed, there will be no evaluation of alert formulas in it.
