Date/Time: Sat, 08 Feb 2025 02:21:37 +0000
Seeking advice : best feed combination for CME and EUREX
View Count: 613
[2020-06-24 11:23:05] |
User877753 - Posts: 152 |
Hello, I have been using the SierraChart feed for years, trading EUREX and CME, with IB as broker (since 2001). What do you suggest I do from July 1st to have access to EUREX and CME, keeping IB as a broker: - sierrachart feed for EUREX and CME - sierrachart feed for EUREX, Denali for CME What is the additional cost of the second configuration? Thank you in advance, Regards, Date Time Of Last Edit: 2020-06-24 11:23:23
[2020-06-24 18:49:12] |
You need to use these two data feeds for this data: Denali Exchange Data Feed (CME Group) Sierra Chart Exchange Data Feed (EUREX) Be sure to refer to the pricing information here for the second listed data feed about the credit you will get to your account: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-24 18:51:30
