Date/Time: Sat, 08 Feb 2025 02:09:05 +0000
ACS folder files .exp and 3D Objects
View Count: 541
[2020-06-24 08:32:39]
User92573 - Posts: 541
Dear Support
I notice numerous additional file now appearing in my ACS folder that were not present when I check back.
Are these actually required or is it simply related to my compile method?
1) Exports Library File (*.exp)
2) 3D Object
3) Object File Library (*.lib)
Each of the above is included for "only" my own compiled studies and not any of Sierra's. Am I okay to clear them all?
Many thanks
Date Time Of Last Edit: 2020-06-24 08:33:33
[2020-06-24 10:04:27]
Those are generated by Visual C++ and you can delete them.
