Date/Time: Sat, 08 Feb 2025 01:56:37 +0000
Daily bar mismatch
View Count: 592
[2020-06-24 01:31:45] |
User790545 - Posts: 41 |
Hello, I'm using the CQG datafeed for both Trading View and SC. There is a difference in the daily bar period chart which is attached. CQG on TV has already rolled over to the next bar whereas SC is still on yesterday's bar. Is there a setting to line up the SC chart? |
[2020-06-24 02:41:02] |
Update, an hour later, the daily bar rolled over (attached pictures) but there is still some differences between the two representations.
[2020-06-24 02:57:29] |
Refer to: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
