Date/Time: Sat, 08 Feb 2025 17:19:36 +0000
2nd computer
View Count: 996
[2020-06-23 23:57:02]
User736044 - Posts: 51
Is it still possible to connect 3 separate instances of Sierra from the same comp to Denali?
I was able to do that but not anymore, once i connect the third one 1 of the other one disconnects.
Thank You!
[2020-06-24 04:58:41]
We reduced the three connections to two connections just to be on the safe side with the exchange.
So you what you need to do is use data sharing between instances for the third instance:
https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart
[2020-06-24 10:35:45]
I see, thanks for getting back to me on this.
So, If i were to pay the exchange fees again for a sec comp , would that be considered a third connection by the CME rules?
Thank You
[2020-06-24 10:40:24]
You should be okay with that. That would be just considered two devices.
[2020-07-06 21:46:09]
Even if I have 2 instances on 1 comp that would be considered one connection, sorry just want to make sure.
Thank You!
[2020-07-08 01:42:59]
Yes. Just one device would be how it is considered.
[2020-07-14 12:57:41]
I'm sorry, but is still not clear to me. In my main comp I have 2 separate installs of Sierra and both are connected to Denali. I understood that is allowed. I paid for one more Exchange fee so I can connect with my second comp and it does not let me.
[2020-07-14 13:01:54]
Reconnect to the data feed:
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
Date Time Of Last Edit: 2020-07-14 13:02:26
[2020-07-15 20:13:33]
I think i did not get the whole thing
Here it is again
Software version: 2135 64-bit | 2020-07-15 15:11:13.657
Primary Thread ID: 19400 | 2020-07-15 15:11:13.657
Usage end date: 2020-08-09 | 2020-07-15 15:11:13.657
Enabled for: Advanced Features 2. | 2020-07-15 15:11:13.657
Enabled for: Sierra Chart Historical Data Service. | 2020-07-15 15:11:13.657
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-07-15 15:11:13.657
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-07-15 15:11:13.657
Enabled for exchange2: CME | 2020-07-15 15:11:13.657
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-07-15 15:11:13.657
Current selected Data/Trading service: SC Data - All Services | 2020-07-15 15:11:13.657
Custom symbol settings values: enabled | 2020-07-15 15:11:13.657
Chart Update Interval: 1000 | 2020-07-15 15:11:13.657
Intraday Data Storage Time Unit: 0 | 2020-07-15 15:11:13.657
Time Zone: -05:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-07-15 15:11:13.657
2020-07-15 15:11:13 Local computer time | 2020-07-15 15:11:13.657
2020-07-15 20:11:13 Local computer time in UTC | 2020-07-15 15:11:13.657
2020-07-15 15:11:13 Local computer time in SC Time Zone | 2020-07-15 15:11:13.657
2020-07-15 20:07:56 Server time in UTC | 2020-07-15 15:11:13.657
Local computer UTC time and Server UTC time difference: 4 seconds. | 2020-07-15 15:11:13.657
Program path: C:\SierraChart\ | 2020-07-15 15:11:13.657
Data Files path: C:\SierraChart\Data\ | 2020-07-15 15:11:13.657
OS Version Number: 10.0 | 2020-07-15 15:11:13.657
Locale Setting: C | 2020-07-15 15:11:13.657
Allowed protected custom studies: Smaug_SC_Library, SST_FreeBundle | 2020-07-15 15:11:13.657
SC Data - All Services | Connected to data server. | 2020-07-15 15:11:18.045
Triggering next historical data download in queue. | 2020-07-15 15:11:18.046
Mapping ESU20 to ESU20. Service code: cme | 2020-07-15 15:11:18.445
SC Data - All Services | Starting real-time market data updates for: ESU20 (ESU20). ID: 1 Service code: cme | 2020-07-15 15:11:18.445
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2020-07-15 15:11:18.445
SC Data - All Services | Requesting security definition data for: ESU20 (ESU20). ID: 1 | 2020-07-15 15:11:18.445
Requesting market depth updates for: ESU20 if supported. | 2020-07-15 15:11:18.445
Separate subscription for market depth updates not supported. ESU20 | 2020-07-15 15:11:18.445
Added historical Intraday data request for ESU20 to the queue. | 2020-07-15 15:11:18.445
Intraday data recording state for symbol ESU20 is set to download 'Pending'. | 2020-07-15 15:11:18.445
Triggering next historical data download in queue. | 2020-07-15 15:11:18.445
DTC Client socket (1) | Creating socket. | 2020-07-15 15:11:18.446
DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2020-07-15 15:11:18.446
Delaying start of download for ESU20 | 2020-07-15 15:11:18.453
SC Data - All Services | Connected to server. | 2020-07-15 15:11:18.460
SC Data - All Services | Starting socket receive thread. | 2020-07-15 15:11:18.460
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-07-15 15:11:18.460
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-07-15 15:11:18.485
SC Data - All Services | Sending logon request message. | 2020-07-15 15:11:18.485
SC Data - All Services | Received logon response. | 2020-07-15 15:11:19.036
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-07-15 15:11:19.036
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-07-15 15:11:19.036
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-07-15 15:11:19.036
SC Data - All Services | Waiting for socket receive thread to end | 2020-07-15 15:11:19.036
DTC Client socket (1) | CloseSocket call. | 2020-07-15 15:11:19.036
SC Data - All Services | Disconnected from the server. | 2020-07-15 15:11:19.036
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-07-15 15:11:19.036
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-07-15 15:11:19.036
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-07-15 15:11:19.052
DTC Client socket (1) | Closed. | 2020-07-15 15:11:19.052
SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2020-07-15 15:11:49.032
DTC Client socket (1) | Creating socket. | 2020-07-15 15:11:49.033
DTC Client socket (1) | Connecting to IP: 216.1.90.130. | 2020-07-15 15:11:49.033
SC Data - All Services | Connected to server. | 2020-07-15 15:11:49.048
SC Data - All Services | Starting socket receive thread. | 2020-07-15 15:11:49.048
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-07-15 15:11:49.048
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-07-15 15:11:49.075
SC Data - All Services | Sending logon request message. | 2020-07-15 15:11:49.075
SC Data - All Services | Received logon response. | 2020-07-15 15:11:49.668
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-07-15 15:11:49.668
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-07-15 15:11:49.668
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-07-15 15:11:49.668
SC Data - All Services | Waiting for socket receive thread to end | 2020-07-15 15:11:49.668
DTC Client socket (1) | CloseSocket call. | 2020-07-15 15:11:49.668
SC Data - All Services | Disconnected from the server. | 2020-07-15 15:11:49.668
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-07-15 15:11:49.668
DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2020-07-15 15:11:49.668
DTC Client socket (1) | Socket gracefully closed by remote side. | 2020-07-15 15:11:49.681
DTC Client socket (1) | Closed. | 2020-07-15 15:11:49.681
HD Request # 2 | Downloading Intraday chart data for ESU20 to the file ESU20.scid. Service: cme | 2020-07-15 15:12:19.593
HD Request # 2 | Download start date-time: 2020-07-15 15:09:04.000 | 2020-07-15 15:12:19.593
HD Request # 2 | Using server: ds21.sierracharts.com port 10149 | 2020-07-15 15:12:19.593
Socket (1) | Creating socket. | 2020-07-15 15:12:19.593
Socket (1) | Connecting to IP: 216.1.90.129. | 2020-07-15 15:12:19.593
HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-07-15 15:12:19.626
HD Request # 2 | Sending historical data logon request message. | 2020-07-15 15:12:19.626
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-07-15 15:12:19.663
DTC Client socket (2) | Creating socket. | 2020-07-15 15:12:19.664
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-07-15 15:12:19.664
SC Data - All Services | Connected to server. | 2020-07-15 15:12:19.687
SC Data - All Services | Starting socket receive thread. | 2020-07-15 15:12:19.687
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-07-15 15:12:19.687
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-07-15 15:12:19.714
SC Data - All Services | Sending logon request message. | 2020-07-15 15:12:19.714
HD Request # 2 | Requesting Intraday data. Start date-time: 2020-07-15 15:09:04. Record interval: 0. Symbol: ESU20 | 2020-07-15 15:12:20.109
HD Request # 2 | Decompressing data. | 2020-07-15 15:12:20.126
HD Request # 2 | Receiving Intraday data for ESU20 starting at 2020-07-15 15:09:04 | 2020-07-15 15:12:20.144
Socket (1) | CloseSocket call. | 2020-07-15 15:12:20.144
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-07-15 15:12:20.145
Historical data download thread signaled to stop. | 2020-07-15 15:12:20.145
HD Request # 2 | Timestamp of first Intraday data file record written: 2020-07-15 15:09:07 | 2020-07-15 15:12:20.145
HD Request # 2 | Received 2118 records from 2020-07-15 15:09:04.000 to 2020-07-15 15:12:23.001 (3.3 minutes) and wrote 2116 records for ESU20 | 2020-07-15 15:12:20.145
HD Request # 2 | Completion time: 1s | 2020-07-15 15:12:20.147
HD Request # 2 | Intraday data download complete for ESU20. Unique request ID: 2 | 2020-07-15 15:12:20.147
Removing historical data download ID 2. | 2020-07-15 15:12:20.147
Real-time Intraday chart data file updates started for ESU20 | 2020-07-15 15:12:20.147
Intraday chart data file opened for ESU20 | 2020-07-15 15:12:20.147
HD Request # 2 | Enabling Intraday chart updating for symbol. | 2020-07-15 15:12:20.147
Triggering next historical data download in queue. | 2020-07-15 15:12:20.147
Socket (1) | Socket gracefully closed by remote side. | 2020-07-15 15:12:20.159
Socket (1) | Closed. | 2020-07-15 15:12:20.159
SC Data - All Services | Received logon response. | 2020-07-15 15:12:20.308
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-07-15 15:12:20.308
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-07-15 15:12:20.308
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 2, NumCurrentConnectionsDifferentDevices = 3 | 2020-07-15 15:12:20.308
SC Data - All Services | Waiting for socket receive thread to end | 2020-07-15 15:12:20.308
DTC Client socket (2) | CloseSocket call. | 2020-07-15 15:12:20.308
SC Data - All Services | Disconnected from the server. | 2020-07-15 15:12:20.308
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-07-15 15:12:20.308
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-07-15 15:12:20.308
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-07-15 15:12:20.322
DTC Client socket (2) | Closed. | 2020-07-15 15:12:20.322
[2020-07-15 20:28:24]
We need to do some testing on this and get back to you. We will do that later today. But can you reconnect all of your installations of Sierra Chart to the data feed:
And see if that resolves the problem.
[2020-07-16 20:02:33]
We have tested this and verified, that the two connections from different devices is properly supported.
This is also confirmed by this:
If you are still experiencing an issue, please reconnect all of the instances of Sierra Chart to the data feed:
Date Time Of Last Edit: 2020-07-16 20:03:55
[2020-07-16 21:53:35]
Ok, so to clarify you can only have 2 separate installations of Sierra Chart at the same time. With one data feed you can run both in the same computer and if you want to use a 2nd computer you need to pay for the exchange fee again, but you have to close one from the first computer
[2020-07-16 21:58:10]
No. You can have two installations on two computers all running and connected to the Denali data feed at the same time if you are paying two exchange fees. So a total of four.
We are testing this now and it works correctly. We have got a total of three installations, two on one system and one on another.
As we said before if you are still experiencing an issue, please reconnect all of the instances of Sierra Chart to the data feed:
Date Time Of Last Edit: 2020-07-16 22:07:00
