Date/Time: Sat, 08 Feb 2025 02:04:22 +0000
Control width of chart scale region
View Count: 906
[2020-06-23 18:43:30] |
Willson - Posts: 176 |
Have not located width control to adjust right scale text region. When using very small font for scale, the allotted region remains much too large. How to adjust?
[2020-06-24 04:53:32] |
The area that contains the Values Scale numbers is not adjustable. That width is set automatically by the chart based on the data that needs to be displayed. Also refer to: Chart Scale and Scale Adjusting: Include in Scale Width Calculation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
