Date/Time: Sat, 08 Feb 2025 02:28:05 +0000
Access Sierra charts through new IB
View Count: 520
[2020-06-23 16:33:18] |
User679285 - Posts: 2 |
I am a sierra chart user...used them with Infinity Brokerage, but now have switched to Edge Clear with Sierra charts. Is there a way to access my saved charts through Sierra/Infinity or do I have to redo all of them now that I'm with a new broker? Thank You Karen Dick |
[2020-06-23 17:56:05] |
Yes you just simply open the same Chartbooks . And then translate the symbols with this command: Edit Menu: Edit >> Translate Symbols To Current Service If when using Transact, Sierra Chart was in a different installation folder, then you will need to move the files. So you may need to move the Chartbook files from C:\SierraChart\SierraChartTransactMA\Data to C:\SierraChart\Data Refer to: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-23 17:56:31
