Date/Time: Sat, 08 Feb 2025 01:57:33 +0000
Using Custom Calculated Symbol feature with external SCID files
View Count: 486
[2020-06-23 16:32:16] |
Blue Brazilian - Posts: 42 |
I generate several SCID files from external sites to plot data on SC charts and they work perfectly. However, when I use these symbols in the Custom Calculated Symbol feature, the resulting calculation plots on the chart, but does not update, even though the SCID files on which the calculation is based are updating regularly. Do I need to set any additional parameters to enable the update? |
[2020-06-23 17:28:55] |
This is not supported with the Custom Calculated Symbols feature. It is not going to work.
