Date/Time: Sat, 08 Feb 2025 02:21:41 +0000
DOM for Es Index
View Count: 589
[2020-06-23 16:26:13] |
User244698 - Posts: 1 |
Hi all, I am having trouble seeing the DOM for the SPy and ES index. I type in the proper ticker and there are no bid/ask prices when i launch the DOM. Please help setting this up |
[2020-06-23 18:27:18] |
Among the symbols mentioned, there will only be market depth data available when using ESU20. Do you see market depth data for that symbol? Refer to: File Menu: Open Market Depth Window (File) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
