Date/Time: Sat, 08 Feb 2025 02:11:27 +0000
Chart title/region data lign alignment
View Count: 1122
[2020-06-23 16:04:38]
User459170 - Posts: 262
Hi, can the chart title/region data line be moved to the right side of the chart? Also Is there a way to display the bar period of the chart along with the countdown timer or separately?
Date Time Of Last Edit: 2020-06-23 16:07:34
[2020-06-23 17:49:46]
1. There is in the latest versions, the Chart >> Chart Settings >> Advanced Settings 3 >> Auto Wrap Chart Header option. Here is an example:
http://www.sierrachart.com/image.php?Image=1592934482560.png
As you can see though, it can cause overlap on the chart bars. But you can always adjust the font size of the chart:
Graphics Settings: Fonts and Text Appearance
2. In order to display the Bar Period differently than what is offered through the Chart Header, you would need to create your own Custom Study. Refer to the information here:
Advanced Custom Study Interface and Language (ACSIL)
It is supported through ACSIL to get all of the bar period settings parameters.
[2020-06-23 18:04:29]
Is there any study that can be edited to just show the current bar period of the chart, i.e. 1 min, 5 min, etc. For example in the Countdown timer, if the text TR could be replaced by whatever the value of the Barperiod is on the chart? Is there a way to do that? Thank you.
[2020-06-23 18:25:11]
This is supported already through the Chart Header. There specifically is a field for this:
Working With Charts: Region Data Line / Chart Header
[2020-06-23 19:12:36]
Yes, its there. I want it to show on the right side top of the chart and more prominantly. If there a way to align it to the right or use it in some way to show up at the top right would be great.
Date Time Of Last Edit: 2020-06-23 19:13:08
