Date/Time: Sat, 08 Feb 2025 02:27:52 +0000
[Programming Help] - Request- Simple Modification to Existing Indicator
View Count: 654
[2020-06-23 13:02:27]
User175873 - Posts: 2
Can someone(SierraChart or any user) send me a cpp file with a hopefully simple modification to an existing indicator please?
Basically I would like the "Period OHLC-Variable Period" indicator for a time period option. There are a few indicators for a time period Indicators:
High/Low for Time Period
High/Low for Time Period-Extended
But currently they display the current time period and the current time period lines displayed without an option to use the current period or not.
Mainly I would like the Period OHLC-Variable Period indicator for a time period option because of the "Use current period" option because lines are extended until the current period ends. Also the Open/Close as options in addition to HIgh/Low. Modifying either High/Low, High/Low-Extended or Period OHLC-Variable with those options would be great. thanks
Date Time Of Last Edit: 2020-06-23 13:12:22
[2020-06-24 11:23:52]
User90125 - Posts: 715
An annotated (marked up) pic of what you really seek, might be helpful.
[2020-06-24 12:40:25]
I seek the "High/Low for time Period"/"High/Low for time Period-Extended" indicator to have the option to use the "Current Period" or not so the lines extend until the current time period ends and get updated. "Use current period" option is in the indicator " Period OHLC-Variable Period" and would like for it to work the same way for "High/Low for Time Period"
@Sierra Chart Engineering
would you be able to add that option to the indicator?
Date Time Of Last Edit: 2020-06-24 12:47:01
