Date/Time: Wed, 19 Mar 2025 19:30:32 +0000
Disable / Deactivate Chart?
View Count: 824
[2020-06-23 12:10:43]
osaga - Posts: 53
Hello SC
Is there a way to disable or "turn off" a chart/window so that it will keep all of it's criteria (days to load, symbol, etc), but it will not load any data (blank chart) or use any CPU power?
I have a set of windows I use every now and then, but they use a lot of data load time. I would like to be able to turn them off until I need them. I would like to do this without having to put them into another chartbook.
Thank You!
[2022-10-29 08:48:10]
caxxxxxx - Posts: 12
Old thread, but same question here - This would be a very nice feature. I turn some DOMs on/off depending on the action of the day / how the correlations are today. I would like to keep these unused windows in some sort of "disabled but ready to go" state without them consuming resources.
[2022-10-31 14:24:40]
John - SC Support - Posts: 38806
You would need to "Hide" the charts you do not want. Refer to the following:
Window, CB and CW Menus: Hide Window (Window)
Also, if you do not want data downloaded for a specific symbol, then refer to the following setting:
Chart Settings: Disable Data File Updating (Disable Historical Data Download) (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
