Date/Time: Sat, 08 Feb 2025 22:13:43 +0000
Tick Size Rectangle Outline Draw Style
View Count: 1440
[2020-06-23 10:31:02]
ninjus - Posts: 32
Hello Support
Love the new transparent tick size rectangle draw styles.
Was hoping we might be able to get tick size rectangle outlines next.
My current work around is using color bar based on alert condition and then using the Bands/Envelope study with 0.5 ticks value and using either the Right Offset Box or Left Offset Box draw style.
Means I end up with a lot of studies.
It is messy.
Be great to just have the option as a draw style.
imagetick-rectangle-outline.png / V - Attached On 2020-06-23 10:30:38 UTC - Size: 106.9 KB - 478 views
imagework_around.png / V - Attached On 2020-06-23 10:30:43 UTC - Size: 166.8 KB - 385 views
[2020-06-28 11:32:05]
ninjus - Posts: 32
Bump
[2020-07-01 14:23:12]
ninjus - Posts: 32
Bump again...
[2020-07-02 09:27:20]
ninjus - Posts: 32
Bump - simple yes or no would be good. Then I'll go away haha.
[2020-07-03 07:15:55]
Sierra_Chart Engineering - Posts: 18339
We have been very busy. We did not concentrate on this. It does not seem difficult. We will look at it closely and see if we can get it done quickly.
[2020-07-03 09:56:26]
ninjus - Posts: 32
You guys rock. Thank you.
[2020-07-26 00:55:49]
ninjus - Posts: 32
Hi
I know you are busy but just wanted to follow up on this.
Can these tick size rectangle outline draw styles be added?
[2020-07-29 19:53:26]
We did not yet get to this but we are going to do this today if possible.
[2020-07-30 09:41:13]
We have completed this and it is now in the latest prerelease.
[2020-07-30 09:44:33]
ninjus - Posts: 32
YEEEEESSSSSSS!!!!!!!
Thank you very much!
[2020-07-30 11:25:40]
binaryduke - Posts: 377
Could these be implemented as ACSIL drawing tools too please? This would be most helpful when one needs to implement this type of drawing without the subgraph quantity limits.
Date Time Of Last Edit: 2020-07-30 11:26:03
[2020-07-30 19:09:41]
Possibly, but this is just yet another item upon hundreds of other items. So perhaps we get to it in years.
