Date/Time: Sat, 08 Feb 2025 02:02:09 +0000
[Programming Help] - sc.CombinedForegroundBackgroundColorRef transparent is possible?
View Count: 546
[2020-06-23 09:24:44]
GiovanniD - Posts: 41
I need to set only the foreground color in some circumstances, is there a way to leave the background color to transparent?
Subgraph_Tempo.DataColor[sc.Index] = sc.CombinedForegroundBackgroundColorRef(RGB(90, 90, 90), transparent);
Otherwise, I can pick up the color value used in the background in the chart so I can put it in the sc.CombinedForegroundBackgroundColorRef?
Piero
[2020-06-23 09:58:12]
No you have to specify the color for the background.
[2020-06-23 10:11:40]
Any way to pick the current backgroung color of the chart?
Date Time Of Last Edit: 2020-06-23 10:11:56
