Date/Time: Sat, 08 Feb 2025 00:33:18 +0000
Gain Capital software support
View Count: 541
[2020-06-23 04:56:48] |
User852998 - Posts: 1 |
Is Sierra Charts able to use the Gain Capital data feed?
[2020-06-23 07:15:38] |
We are not recommending this for new users. So the answer is no. The supported services are here: Supported Data and Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
