Date/Time: Fri, 07 Feb 2025 23:51:59 +0000
MJYU2020 Weird Data
View Count: 647
[2020-06-22 19:02:30]
User790545 - Posts: 41
Attached is a file of the daily MJYU2020 chart (CQG data feed). Please advise on how to correct this.
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=40632
[2020-06-22 20:23:47]
Reconnect to the data feed:
And then re-download the data:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2020-06-22 22:50:21]
I did this and it briefly showed the correct data and then went back to showing what it did before.
[2020-06-23 02:11:48]
Okay, we apologize for this. We did not pay close enough attention to it. This is now resolved.
After this:
[2020-06-23 02:23:56]
Works again! Will keep this thread open for a bit to see if it goes back.
[2020-06-23 04:46:20]
You will not have a further problem with this.
