Date/Time: Fri, 18 Sep 2026 04:52:45 +0000
Which Denali Exchange
View Count: 1083
| [2020-06-22 17:54:22] |
| JimmysBrother - Posts: 2 |
I am using Interactive Brokers and seeing that their data with the footprint is just off. (I need the accurate data for SPY and Future, E-mini and Micro) I was wondering which Denali Exchange and add-ons I needed to get accurate data. From my understanding Denali cost $25 and then I need to also get [Todo] Activate / Deactivate Denali Exchange Data Feed Exchanges (required) and they range from $41.60 all the way to $386.25 If you could tell me which service I need (at the lowest cost) that would be great bc I am a bit lost in which ones to choose. |
| [2020-06-22 20:45:15] |
For SPY you need to use the Sierra Chart Exchange Data Feed and the US Equities exchange: Sierra Chart Exchange Data Feed For Future, E-mini and Micro , you need to use the Denali Exchange Data Feed and the CME Group of exchanges:Denali Exchange Data Feed If you are a nonprofessional the exchange fee is 3.25 USD per month. Since you will be using both data feeds you get a 12 USD credit to your account each month. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-22 20:47:08
| [2020-06-23 12:14:40] |
So the only problem i keep having is the prices aren't starting at $3.25 on any of my pages, for the {3. [Todo] Activate / Deactivate Denali Exchange Data Feed Exchanges (required)} my prices start at $41.60. I also just noticed that my account has been tagged as a "Professional" account. would this have anything to do with why i'm not seeing those prices? |
| [2020-06-23 17:23:24] |
Yes, since you have been tagged as a professional, you will not see the lower-priced options. It looks like the reason you were classified this way is that you did not have a trading account that you could use to validate your status with the CME. Refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges It looks like you now have an account with Interactive Brokers. Please fill out the Denali Exchange Data Feed Agreements again on this page and be sure to specify Interactive Brokers as your Clearing Firm: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
