Date/Time: Sat, 08 Feb 2025 00:33:15 +0000
Chart and DOM not recognizing the other's orders/positions under the Rithmic connection
View Count: 776
[2020-06-22 17:53:14] |
User854802 - Posts: 43 |
Hi I just set up a Earn2Trade account using rithmic, which I known you guys hate and seems a pain in the ass. But I figured out the bridge connection and I got data and everything. The problem I have now is my DOM and Chart are not showing my orders/positions in the other. Like if I open a market buy on the DOM, nothing shows up on my tick chart. And viceversa if I open a position from the chart, nothing shows on the DOM. And even if I hit "Flatten" on the DOM it does nothing and I get en error message on the activity log saying there is no order open to cancel. I have both set up in the current Sept ES contract. This is very frustrating cause I am trying to do a prop tryout but obviously I cannot do anything if those 2 things are not in sync with one another. When I switch into Sierra's SIM trading more it works fine and all the orders sync and show on both, etc. Any idea what is going on that the chart and DOM are not working together under the Rithmic connection? Thanks |
Screenshot_1.png / V - Attached On 2020-06-22 17:53:02 UTC - Size: 143.1 KB - 226 views |
[2020-06-22 20:41:16] |
Follow the instructions here related to this: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM It sounds like it is a case where the Chart and Trading DOM are set to different Trade Accounts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-22 21:01:12] |
SpearChucker - Posts: 104 |
Sounds similar to an issue I had. If Sierra Chart Engineering's post didn't resolve the issue, take a look at this thread. Current Open Position Line - Missing |
