Date/Time: Mon, 03 Mar 2025 17:56:38 +0000
Denali data feed trial.
View Count: 1519
[2020-06-22 14:04:21] |
User929084 - Posts: 60 |
Hi. 1. I would like to try Denali data feed. I read that 1st month is free. Do I need to pay exchange fees while on trial? I only need CME for ES and NQ. 2. Should I wait till beginning of next month to do that? Since there's only 7 trading days left in June. |
[2020-06-23 03:11:53] |
1. As long as you have not used the data feed in the past, then both are free for the first month in which they are activated. 2. Yes, you should wait until the beginning of next month. If you activated the data feed and exchange today, you would only get 8 days of free usage (until June 30, 2020). If you start at the beginning of next month, then you would get the entire month of July for free. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-29 21:58:33] |
1. I have never used Denali feed. 2. What can I do now to prepare for July 1st to get the data feed? Do I need to fill out forms, sign something? Right now I'm with AMP futures on CQG data feed. 3. While on Denali trial feed, will I be able to trade live through my current AMP account? 3.a. Is Denali data feed trial just data feed or data feed with Sierra Chart order routing service? 4. Will my log in stay the same? |
[2020-06-30 19:23:23] |
1. Then you should have no problem getting the data feed cost and the exchange fee cost for free the first month. 2. You can start by signing the Data Feed Agreements. You can do that now. You will find the agreements here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements 3. Yes, you can still trade through your CQG account with AMP. You will not need to make any changes to your Data/Trade Service Settings to get the Denali Exchange Data Feed. Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services 3a. It is just the data feed. If you also want the Sierra Chart Order Routing Service, then that would be another process to go through to get setup, and you would then not be trading through CQG, but instead would be trading through TT. In your case, you would want to get that setup through AMP, so you would need to talk to them about it. You can get more information here: Sierra Chart / Trading Technologies Futures Order Routing Service 4. Yes, your login will stay the same. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-30 19:23:46
[2021-11-02 04:48:33] |
jayodas - Posts: 4 |
I'm signing up for my Denali data feed trial now. In the Exchange Agreements - Uniform Subscriber Agreement, it asks for Trading Account Number and Clearing Firm. I'm going to use Interactive Brokers for this so do I put down Interactive Brokers the Clearing Firm? |
[2021-11-02 10:57:09] |
In this case clearing firm would be Interactive Brokers.
[2021-11-04 09:19:41] |
I've selected package 12 from available services. And connected Sierra Chart to my Interactive Brokers account. When I go to activate the Denali Data Feed, it doesn't work and the result messages say: Failed to activate the 'CME with Market Depth for nonprofessional Trading accounts' exchange. The Data Feed is not enabled on the account. What do I need to do to get the trial working? Thanks. Date Time Of Last Edit: 2021-11-04 09:28:55
[2021-11-04 13:51:59] |
John - SC Support - Posts: 38327 |
You have selected Package 12 as the package that your account will renew to when your trial ends. In order to activate the exchanges for the Denali Exchange Data Feed, you need to be on Package 12 at this time. To do this go to the following page and in the section for Choose Service Package and Time Period for Usage Time, or "Disabled" select the button for Update and Renew Now. This will remove $56.00 from your Services Surplus in exchange for Package 12 for one month. https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#AvailableServices If you do not have enough funds in your account, then you can add funds on our Payments page, which is at the following link: https://www.sierrachart.com/UserControlPanel.php?page=AddAccountCredit For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-05 13:34:50] |
Ok, I've got the Denali data feed activated, but I don't see BMO data. I've added the Bid Market Orders and Ask Market Orders column to my DOM but they are always empty. |
[2021-11-05 15:00:14] |
Go through the instructions at the following link to ensure you have everything setup properly: Market By Order Data: Step-by-Step Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-11-05 15:00:31
