Date/Time: Sat, 08 Feb 2025 02:07:55 +0000
ERROR
View Count: 565
[2020-06-22 13:03:56] |
User91670 - Posts: 29 |
Hello, I'm getting the following error message when I change the chart timeframe - it started after the recent update.
Date Time Of Last Edit: 2020-06-23 10:19:37
Private File |
[2020-06-23 10:19:06] |
In one of the lines that says "Error opening file", there is a full path and filename. Can you attach one of the files here so we can test it and see what the problem is. Instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-23 10:19:16
