Date/Time: Sat, 08 Feb 2025 00:08:58 +0000
cboe $OIV oil volatility index
View Count: 746
[2020-06-22 12:52:50] |
User843333 - Posts: 14 |
I am currently subscribed to CBOE exchange using SC data feed. For VIX I get real time quotes but for CBOE $OIV seems to be delayed 1 week :( Can you please tell me what could be the problem? thx |
[2020-06-22 21:00:47] |
We have asked our data provider about this. We do not know the reason for this. The data has stopped from the source on 2020-05-15.
[2020-06-22 23:04:32] |
Response: Yes this is correct, the CBOE stopped sending a number of indexes.
$OVX is similar and still active. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
