Date/Time: Sat, 08 Feb 2025 02:24:27 +0000
How to copy Dom
View Count: 1634
[2020-06-22 11:20:12]
Daniel Widmar - Posts: 24
Hey guys how can i copy the customized dom to other symbols. Or better to my quote board. When i click on any symbol on my quote board it does open all my charts to the symbol but the dom does not change. any help?!
[2020-06-22 21:46:46]
ForgivingComputers.com - Posts: 996
Use Symbol links on your chart, DOM, and Quote board. DOM Chart settings are the same as a regular chart. Go to the Advanced 2 tab.
[2020-06-23 10:48:26]
To copy a Customized Trading DOM, you just need to use the Chart >> Duplicate Chart command and then change the symbol. Refer to the information here:
Using Chart Templates: Duplicating Charts / Template Charts
To change the Trading DOM to the selected symbol on the Quote Board, you just need to make sure that the Trading DOM is linked properly, just like any other chart. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
