Date/Time: Sat, 08 Feb 2025 00:34:50 +0000
I need help to change older 32 bit chart books to newer 64 bit.
View Count: 528
[2020-06-22 00:57:14] |
User992108 - Posts: 31 |
Looking for a programmer that is capable of changing older 32 bit chart books to newer 64 bit.
[2020-06-23 03:12:27] |
This request does not make sense. Chartbooks require no conversion. Maybe you are referring to custom studies in which case refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
