Date/Time: Sat, 08 Feb 2025 00:06:56 +0000
Data mismatches between platforms
View Count: 536
[2020-06-21 18:38:07] |
User869657 - Posts: 31 |
Hello, Using two different platforms, we have noticed some discrepancies when downloading Futures Dax data (both platforms had the same Chart Settings and General Settings). The mismatches that we have noticed are the following : 1) The .scid generated by the old platform is 3 times heavier (for example for DYH13, it was 90,000 KB vs ~ 30,000 KB 2) The study "Cumulative Delta Bars - Volume" was showing similar values for the Open/Close/High but the low was different for almost all the bars. The versions use are both 2102. We understand that a difference of settings between the two might explain the above but we couldn't figure out which ; could you please let us know which settings might have triggered such behaviour ? As always, thanks vm for your help |
[2020-06-21 21:22:15] |
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Make sure this is the case for both installations of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-21 21:22:25
