Date/Time: Sat, 08 Feb 2025 02:15:57 +0000
AMP CQG Historical Intraday starting from June 2012 - no longer 10 years of data.
View Count: 207757
[2020-06-21 17:47:07]
User155152 - Posts: 10
Hello
when I download historical intra-day data from CQG the starting date is June 2012.
It used to be 10 years of intraday data (start from 2010) until recently.
looking at the logs I noticed the CQG returns nothing to requests of futures contracts earlier than June 2012.
I presume you are aware of this change. Can you please confirm.
Also, can you please provide a workaround? in the SierraChart historical intraday included in the AMP package?
thanks
[2020-06-23 03:10:15]
For longer-term historical data you need to use the Denali Exchange Data Feed:
Assuming you require data from the CME Group of exchanges.
No.
Date Time Of Last Edit: 2020-06-23 03:10:24
[2020-06-23 09:10:38]
thank you.
Option: I would like to try instead the SC Historical Data Service included in the SC Standard Package.
Reason: it will give me access to historical data beyond CME for back testing purposes.
Problem: my SC package sponsored by AMP does not allow me to select any other package.
Solution: create another SC Account? fund it? enable the package?
thanks
[2020-06-23 09:37:55]
Direct Sierra Chart Account
When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below:
