Date/Time: Fri, 07 Feb 2025 23:49:49 +0000
32 bit to 64 bit
View Count: 830
[2020-06-21 17:07:33] |
User227335 - Posts: 5 |
I'm having trouble viewing my custom studies after doing the upgrade. Is there a way to switch from 32 bit to 64 bit? Maybe that's the issue?
[2020-06-21 17:18:25] |
Ackin - Posts: 1865 |
Same question as in your previous thread: "Custom studies" - do you mean your own studies for which you have the source code or do you mean usercontributed studies? Custom Studies Question ********************************** If you have the source code for those studies, it must be recompiled into the 64-bit version. Below in the links you have a link for it. ********************************** How to Build an Advanced Custom Study from Source Code How to Build an Advanced Custom Study from Source Code Difference Between 32 and 64-bit Versions Software Download: Difference Between 32 and 64-bit Versions Advanced Custom Study Errors How to Use an Advanced Custom Study or a Study Collection: Advanced Custom Study Errors Custom Study Not Listed or Not Displaying on Chart How to Use an Advanced Custom Study or a Study Collection: Custom Study Not Listed or Not Displaying on Chart Study Exceptions in New Versions and Code Efficiency Notice: Study Exceptions in New Versions and Code Efficiency Date Time Of Last Edit: 2020-06-22 06:17:42
[2020-06-21 19:47:34] |
So how do I switch my system from 32 bit to 64 bit? Yes I have the source code along with others. I assume when they update they will experience the same issues.
[2020-06-21 21:50:16] |
Always Run 64 Bit Version (Global Settings >> General Settings >> General 4)
https://www.sierrachart.com/index.php?page=doc/GeneralSettings.html#AlwaysRun64BitVersionWhen this option is selected, then Sierra Chart will always run the 64 bit version of the software rather than the 32 bit version. Otherwise, whichever option is selected to start will be the one that runs. How to Build an Advanced Custom Study from Source Code - Step-By-Step Instructions In your case, see "steps 9 to 12" How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions |
[2020-06-22 04:33:17] |
Sierra_Chart Engineering - Posts: 18336 |
First, first refer to this page here: Resolving Custom Study File and Access Issues You may need to rebuild your custom studies to match the 32-bit or 64-bit version you are running. Instructions are here: How to Build an Advanced Custom Study from Source Code: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
