Date/Time: Sat, 08 Feb 2025 00:05:14 +0000
Problem with excel
View Count: 674
[2020-06-21 14:01:15]
Eric - Posts: 21
Hi, I'm trying to setup excel for backtesting.
I've input the buy entry condition and it automatically enters for me for all the rows. But it doesn't do the same for the buy exit, sell entry and sell exit columns.
I tried to drag it down or double click like what I normally do with MS excel but still won't work.
May I know if I've done something wrong?
It's quite tedious to enter manually and there should be some way to get this done.
Date Time Of Last Edit: 2020-06-22 00:05:34
imageIMG_20200621_215436.jpg / V - Attached On 2020-06-21 13:56:35 UTC - Size: 6.69 MB - 227 views
[2020-06-21 23:54:13]
Eric - Posts: 21
I'm talking about the spreadsheet in Sierra chart
[2020-06-22 00:03:38]
Yes they are not using Microsoft Excel.
You need to enable Global Settings >> Spreadsheet Settings >> Spreadsheet Study >> Recalculate the Chart When a Formula Column Is Changed.
Refer to:
Global Settings Menu: Spreadsheet Settings (Global Settings menu)
