Date/Time: Mon, 25 Nov 2024 07:49:23 +0000
Trying to go back to a previous version
View Count: 1181
[2014-01-27 13:51:30] |
todds - Posts: 64 |
I was using a previous version with OEC with no problems (992 I think) and just downloaded the new version because of a prompt from sierra charts to upgrade. I would like to go back to a previous version but keep getting the error message: can't write: C:\SierraChart\SierraChart.exe |
[2014-01-27 16:54:30] |
You need to make sure that Sierra Chart is not running when the Sierra Chart installer is run. We recommend using version 1078 for now: http://www.sierrachart.com/downloads/1078SierraChartSetupPrerelease.exe This version can be used with OEC without any problems. The newest version, has some work being done relating to the OEC connection. We should have this resolved hopefully today or tomorrow. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-27 17:24:09] |
todds - Posts: 64 |
Should have thought of that myself! Thanks
