Date/Time: Sat, 08 Feb 2025 00:21:51 +0000
Chartbook Overlaps
View Count: 620
[2020-06-19 21:35:16] |
User346878 - Posts: 5 |
I'm trying to add an external chartbook but when i do, it overlaps with my current setup. It inserts the new charts into all my chartbooks and if i remove one of the new charts, it removes it from everywhere.
[2020-06-19 22:26:26] |
What you are describing is fully impossible. This cannot be a correct technical explanation.
[2020-06-19 22:28:58] |
Well, it is happening..
[2020-06-20 03:30:18] |
Step-by-step tell us exactly what you are doing within Sierra Chart including menu command usage, and then just tell us one of the issues that you notice.
[2020-06-20 10:53:16] |
Click file -> open chartbook -> select the one from the menu. It adds the new chartbook (tpo) which has 4 different charts in it. But the problem is, it adds those four charts into every other chartbook as well and when i try to remove the charts from a single chartbook, it deletes them from everywhere. |
[2020-06-20 14:41:45] |
Figured it out. All the charts in that chartbook were set to "Window Always Visible". Disabling that option solves the problem.
[2020-06-23 02:34:03] |
Yes this does make sense.
