Date/Time: Sat, 08 Feb 2025 00:27:21 +0000
[Programming Help] - SimpleMovAvg returns 0
View Count: 561
[2020-06-19 18:06:38]
DonMattez - Posts: 8
in some instances, this code
int InMALength = 8;
int InSubGraph = 2;
sc.SimpleMovAvg(sc.BaseDataIn[SC_LAST], sc.Subgraph[InSubGraph].Data, InMALength);
float FlTrendBefore = sc.Subgraph[InSubGraph].Data[sc.Index - 1];
float FlTrendActual = sc.Subgraph[InSubGraph].Data[sc.Index];
behaves differently than expected.
In this case, FlTrendBefore is 0 at the the index 121. But it should be a value more or less close to FlTrendActual , which contains the actual value at the index 122.
Do you have an explanation why it could be so?
[2020-06-20 21:23:05]
I tried many diffferent attemps now. A strange thing I noticed is the following:
I placed a simple moving average at the begoinning of my code, just to see the results. And as i expected, the output-subgraph of the SMA never had 0 as a value.
Then I returned to the original state of the code - and while debugging I noticed that also I never had 0 as a value.
But the I opened up the chart studies windows, and as soon as I clicked on okay, without changing anything, the 0-values returned.
I noticed this because I am displaying my study, and the output changes from the correct expected result to a the wrong ones, caused by the 0 values in the output array of the SimpleMovAvg function.
Does anyone know why it would be like that?
Thank you.
Edit: I deleted every other study to explude any interferences, still the same...
Date Time Of Last Edit: 2020-06-20 21:30:05
