Date/Time: Sat, 08 Feb 2025 03:13:27 +0000
how to i set my futures charts to do auto rollover?
View Count: 623
[2020-06-19 15:03:43] |
User61576 - Posts: 445 |
I am using SC data and want on days like today to do an auto rollover is this possible? |
[2020-06-19 19:21:12] |
The setting you are looking for is this one: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-21 18:31:58] |
just to make it clear, if I set this in the general settings(4) than I need to set the chart settings for continuous contracts to be set on "none"?
[2020-06-23 03:46:05] |
No that is not correct. The two settings are separate from each other.
[2020-06-24 17:28:41] |
can you pls make it clear to me when to use any of this different setting?
[2020-06-24 19:38:37] |
We recommend only using this setting: General Settings Window: Detect Rollover Of Current Futures Contracts Symbols Based On Real Time Volume (Global Settings >> General Settings >> Charts >> Symbol) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
