Date/Time: Fri, 07 Feb 2025 23:53:02 +0000
Limit Data Export
View Count: 567
[2020-06-19 14:59:14] |
User439067 - Posts: 48 |
I'm having trouble downloading price data into Excel for a project. When I do the export I reach Excel's row limit doesn't load the info I need and its impossible to work with that much data. I just need the last n bars of data exported. Trying to limit the data on my chart by using the 'date range in file' and the date ALWAYS reverts back to the date that was arbitrarily in there. Starting a new chart always dumps the same settings in which I can't seem to successfully change. A guide on how to limit the data in your chart would be helpful - also a feature request that allows us to specify how many bars of data we need on exporting would be helpful. Any advice please? Very grateful thank you. |
[2020-06-19 19:38:33] |
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. Refer to this setting which sets how many days to load into the chart: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Then use this export option to only export the data that is in the chart: Edit Menu: Edit >> Export Bar Data to Text File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-19 19:38:45
[2020-06-19 19:53:36] |
User652942 - Posts: 1 |
All set.
