Date/Time: Fri, 07 Feb 2025 22:44:33 +0000
[Programming Help] - Studie calculation
View Count: 573
[2020-06-19 10:47:41] |
User62448 - Posts: 13 |
Hello, I failed to find a real solution in the support board for my problem. Is there a way to recalculate a studie after every bar and not after every tick? And also to switch off the recalculation completely, so its only calculating after apllying the studie? I`ve tried to solve this with sc.UpdateStartIndex, but I didn`t make it. Thanks! |
[2020-06-19 11:54:31] |
User907968 - Posts: 826 |
You can find some information at the links below that may help: sc.GetBarHasClosedStatus() ACSIL Programming Concepts: One Time Calculations That Do Not Run During Study Updating |
[2020-06-19 13:26:53] |
Thanks a lot!! I will try! |
