Date/Time: Sat, 08 Feb 2025 00:20:29 +0000
Trial extension
View Count: 500
[2020-06-19 07:49:30] |
gr93 - Posts: 18 |
Hi, may I please have my trial extended by 30 more days?
Date Time Of Last Edit: 2020-06-24 05:57:43
[2020-06-19 14:19:03] |
John - SC Support - Posts: 37842 |
We have extended your trial by 5 additional days. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
