Date/Time: Sat, 08 Feb 2025 02:21:37 +0000
[Programming Help] - Tick size in commodities problem
View Count: 664
[2020-06-19 07:21:01] |
User483232 - Posts: 1 |
Hi, The tick sizes in commodites are priced in 25 cent intervals not 1 cent like it should be and I can't draw trend lines correctly. In the indices everything seems fine. Tried clearing everything of Sierra charts from computer memory and then reloaded. That didn't help then tried the beta version too and failed again. Thanks |
[2020-06-19 12:46:13] |
Ackin - Posts: 1865 |
Look: Chart Drawing Tools: Having Tool Values Adjust to the Nearest Tick |
[2020-06-24 05:56:46] |
Hi, The tick sizes in commodites are priced in 25 cent intervals not 1 cent like it should be The tick sizes are set correctly for the futures contracts.Also refer to this section as given above: Chart Drawing Tools: Having Tool Values Adjust to the Nearest Tick Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-24 05:56:57
