Date/Time: Fri, 07 Feb 2025 23:21:06 +0000
[User Discussion] - windows position multiple configurations
View Count: 515
[2020-06-18 13:37:15] |
User843333 - Posts: 14 |
I use different chartbooks with multiple windows, each chartbook with a specific instrument. from each chartbook main trading window I detach it and set "window always visible" and have a place on my desktop where I put each main window from each chartbook so I can see main action from each instrument in the same time. When I want to go back to each chartbook and put each window back I need to do the same process in inverse way (disable - window always visible + attach window back). this process takes me time to do with each window that even with keyboard shortcuts. There is any way that I can save windows and positions in those 2 working modes and switch between them? (one with each window attached in his own chartbook and second work mode with general view) ? thank you |
