Date/Time: Fri, 07 Feb 2025 22:49:29 +0000
QuoteBoard text truncating
View Count: 597
[2020-06-18 11:16:07]
Frostation - Posts: 16
I am having an issue where the "Name" section of the quoteboard appears to be surrounded by a small green rectangle which is pushed to the left meaning the text in the name field truncates.
I have tried changing graphic settings but have had no luck.
imageScreen Shot 18-06-2020 at 12.10.png / V - Attached On 2020-06-18 11:15:14 UTC - Size: 45.67 KB - 231 views
[2020-06-18 18:04:54]
You just need to grab and drag the end of the "Name" column to the right. You cannot see it, but that section is not extending all the way to the end of the window. Refer to the information here for how to change the size of a column:
Getting Quotes: Adjusting Column Widths
Also refer to this section here to set a more clear color to indicate a more clear separation between the header columns:
Graphics Settings: Setting Colors for List View Headers
