Date/Time: Fri, 07 Feb 2025 22:42:57 +0000
control bar buttons
View Count: 684
[2020-06-18 09:13:00] |
grantx - Posts: 244 |
Version 2113 64-bit. How do I get the control bar buttons back? They are text-only at the moment. |
[2020-06-18 09:20:06] |
Ackin - Posts: 1865 |
Try: Control Bar: Control Bar Button Properties |
[2020-06-18 09:26:17] |
Cool thanks. But why did they change this to a text default? I have to go through every button now and set the image. Can we get a global default button somewhere? |
[2020-06-18 09:29:22] |
2065 Release Date: 2020-03-11
Control Bar buttons for drawing tools now use single or multiline text with an 8 point font size by default. This is because the previous images are too small on 4K monitors and based upon the color of the button, they may not be well visible. While larger images could be used for higher resolution monitors, text is very easily scalable based on resolution. There is also no question as to the particular drawing tool that a button is for. It is supported to use the previous images. To do this, follow the Control Bar Button Properties instructions and in particular follow step 10. We are not intending to cause users any difficulties, but there was a significant issue with the images where they were not legible on very high resolution monitors. This has been reported many times to us. And images in general, have difficulty with scaling and visibility problems based on the background color. This is why we deliberately came up with a method and took the detailed time to implement this, by which you could still use the default drawing tool image but not have to specifically select a particular image file. This is a very easy process through the Control Bar Button Properties window where you press the Reset button and choose the option to Use Image. This is all. It is a few seconds per button. Also, you do not even have to use the Reset button either. We are just saying that for completeness. https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Can we get a global default button somewhere?
I don't know...I don't think that's possible
[2020-06-18 15:26:57] |
Refer to the notes here: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
