Date/Time: Fri, 07 Feb 2025 23:25:15 +0000
Sierra Chart Real time data feed and CME Group real time data feed
View Count: 559
[2020-06-18 08:00:23] |
StanislavChentsov - Posts: 6 |
Hi, I checked all forum about possible options for connection. Can I connect Real-Time Data Feed EUREX (non-prof with Market Depth) from Sierra Chart and I have to connect to another Trading Service for CME group Real-Time Data? Example: I purchase CQG or Rithmic Data for CME and Data from Sierra for EUREX? Do I understand right? I need these two connections only for my Simulation Trade Mode. Thank you for your answer. |
[2020-06-18 15:48:55] |
Yes this is certainly supported. EUREX data is provided by this service: Sierra Chart Exchange Data Feed The Denali Exchange Data Feed provides CME group data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-18 15:49:18
