Date/Time: Sat, 19 Sep 2026 05:06:45 +0000
configuration trading IB uing CQG
View Count: 706
[2020-06-18 04:22:53]
User691398 - Posts: 27
I did submit this question to support board but no responds.
I made progress, but don't know how to get IB integrated.
I am running AMP futures using CQG data feed.
Trying to share CQG data feed with Interactive brokers.
I followed this link
Instructions For Sharing Data Between Separate Installed Instances
I successfully instilled second instance and based on the instructions, and is running great in both instances but only AMP account, I don't know how to get IB (interactive brokers) account working
The understanding I thought is sharing data feed for multiple brokers. In this case AMP and IB
help
[2020-06-18 07:03:35]
There is no answer to this for several reasons. Your account is expired, this is advanced usage, and it is something we are just not willing to provide support for. You have to rely upon the documentation.
We are not going to get involved in this. You need to follow our proper established procedures and that is to use the Sierra Chart Real-time Exchange data feeds, with the Interactive Brokers:
Real-Time Exchange Data Feeds Available From Sierra Chart
If you want to use CQG for a scenario like this, you are fully on your own. Simple as that. Do not ask us for help. You are not going to get it.
And besides we have no idea exactly what the problem even really is unless we go through this thoroughly in detail, using a remote assistance session which is all chargeable and based upon our available time. We are not going to get involved in this.
Use these data feeds with Interactive Brokers and you are all set:
You will have a stable and reliable solution.
Date Time Of Last Edit: 2020-06-18 07:04:12
