Date/Time: Tue, 22 Sep 2026 22:12:50 +0000
Historical Data Download failure just on /ES chart
View Count: 870
| [2020-06-18 00:17:37] |
| User74987 - Posts: 16 |
These past 2 days I have tried to load, and work thru the prior suggestions for similiar issues in the support board for my problem (disconnect from data, delete scid file, reconnect, reload) and tried port 80 to download. Nothing works. I use a quoteboard linked to my chart and the other symbols load just fine. Only /ES fails to load. Please help me? Thank you. It seems like the dates for the chart settings get deleted only when I try to load /ES chart. I try to enter new ones. It will allow me to enter the first (from) but won't allow me to enter anything in the second (thru). Error message follows. Real-time Intraday chart data file updates started for ESU20 | 2020-06-17 19:07:56.756 Intraday chart data file opened for ESU20 | 2020-06-17 19:07:56.756 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2020-06-17 19:07:56.756 Triggering next historical data download in queue. | 2020-06-17 19:07:56.756 Error opening Intraday file: Header check failed when opening the file C:\SierraChart4Stage5\Data\ESU20.scid for adding records. Error: Unknown Intraday file type. Header error. | 2020-06-17 19:08:01.764 * File open error encountered. Not allowing writing. C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:01.764 ESU20 [CB] #4 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart4Stage5\Data\ESU20.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:08.768 * Unknown Intraday file type. Header error. C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:32.621 * ESU20 [CB] #2 | Error opening or reading chart data file. File: C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:32.621 * Unknown Intraday file type. Header error. C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:57.643 * ESU20 [CB] #4 | Error opening or reading chart data file. File: C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:57.659 * Unknown Intraday file type. Header error. C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:57.784 * ESU20 [CB] #3 | Error opening or reading chart data file. File: C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:08:57.784 * ESU20 [CB] #1 | Failed to get dates from Intraday data file. Header check failed when opening the file C:\SierraChart4Stage5\Data\ESU20.scid for reading. Error: Unknown Intraday file type. Header error. File: C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:09:26.581 * Unknown Intraday file type. Header error. C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:09:44.006 * ESU20 [CB] #1 | Error opening or reading chart data file. File: C:\SierraChart4Stage5\Data\ESU20.scid | 2020-06-17 19:09:44.006 * |
| [2020-06-18 16:30:15] |
The intraday data file has been corrupted.You need to delete the ESU20 Intraday data file following the instructions here: Chart Data and Chart Data Files: Deleting a Chart Data File You can then reopen the chart or Chartbook for it. The file will then be re-created. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-18 16:32:42
