Date/Time: Fri, 07 Feb 2025 23:22:54 +0000
[User Discussion] - Historical data
View Count: 551
[2020-06-17 22:03:27] |
Tomas21 - Posts: 23 |
I would like to scan stocks using historical / eod close prices for around 4000 stocks , if I upgrade to level 5 can I download these closing prices without restriction? (I'm worried about your info "The limitation for the number of Historical Daily data requests is 30,000 per month. This applies primarily to Historical Daily data requests only and not historical Intraday data requests."), perhaps you could explain what this means , i.e. is each stock request a data request each day , or are they lumped together in one request ( which would be fine) ?
Date Time Of Last Edit: 2020-06-18 08:10:58
[2020-06-18 15:50:15] |
You do not need Service Package 5 for this. Instead on this page you can purchase additional Historical Daily data downloads for the month: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation Each historical Daily data download for each stock is one request. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-18 15:51:06
