Date/Time: Fri, 07 Feb 2025 23:59:49 +0000
Volume By Price Negative Volume
View Count: 581
[2020-06-17 16:58:29]
User769890 - Posts: 4
Can you please clarify the negative volume shown here in the attached PNG file? I researched previous support questions and cant seem to find an answer.
Thank you
imageNegative_Volume_Sierra_Chart.png / V - Attached On 2020-06-17 16:56:50 UTC - Size: 219.29 KB - 239 views
[2020-06-22 00:57:15]
We think it is related to this:
We are releasing version 2125 which resolves this problem, in about 20 minutes.
The issue only affects the Volume by Price study when used with the TPO Profile Chart study.
It is the result of correcting another problem, with intermittent incorrect mapping of single price values to the right price increment, which is due to floating-point error. This was a tricky problem to resolve and the solution was not applied to TPO Profile Charts. And it caused an inconsistency leading to this issue of decreasing volume at price levels.
