Date/Time: Fri, 07 Feb 2025 23:04:49 +0000
SierraChart AMP Futures Rithmic cant connect. Rim files replaced still doesnt work
View Count: 538
[2020-06-17 16:14:24]
User999098 - Posts: 1
i have a new datafeed rithmic via AMP futures and it wont connect. I wasnt able to connect before and was able to sign-in via R-Trader and agreed the terms.
A supporter of AMP futures was on my PC checking and said that usually it should help for teir customers and due this method didnt work on me i should contact you.
I attached a screenshot of the log-file. (See attachments)
Kind Regards
imageSierraChartRithmicAMPfutureserror17062020.jpg / V - Attached On 2020-06-17 16:12:18 UTC - Size: 214.89 KB - 294 views
[2020-06-17 17:45:36]
Refer to the information here:
Rithmic Bridge Files and Updated TLS Certificate Files Needed for June 1, 2020 and Onward (which you have seen)
and here:
Regarding Rithmic (Our Final Post on this Subject)
Date Time Of Last Edit: 2020-06-17 17:46:19
