Date/Time: Fri, 07 Feb 2025 22:54:47 +0000
SC order routing with SC data feed?
View Count: 606
[2020-06-17 14:02:11]
User843333 - Posts: 14
Can I have SC order routing trough TT FIX connection with SC data feed (barchart) ? or only with Denali exchange data feed
[2020-06-17 17:39:14]
You can have both data feeds with the Sierra Chart Order Routing.
But you would need to check with your broker on what exchanges they offer support for with TT for trading.
[2020-06-17 18:04:43]
I would like to have real time $VIX (CBOE). At this moment with Denali data feed it seems to be delayed. I do not want transact $VIX just to have real time data feed of it.
that means I need to change from Denali data feed to SC datafeed?
[2020-06-17 19:39:26]
This is a cash index which is included with the CBOE Indices exchange. Therefore, refer to:
Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes
Later in the year we do plan to offer the CBOE volatility futures with the Denali data feed.
[2020-06-17 20:20:21]
If I cancel Denali data feed and add Sierra charts data feed then I would need to activate the following exchanges:
1. Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts
2. CBOE Indices
at this link https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures I couldn't find where to activate Full CME Group for SC datafeed. this isn't available anymore for SC data feed and only for Denali?
In order to use Full Cme Group + CBOE indices in the same time it is a must to have both Denali (with CME group) + SC datafeed (with CBOE Indices) ???
[2020-06-17 21:38:24]
John - SC Support - Posts: 37842
Your last statement is correct. You need the Sierra Chart Exchange Data Feed for the CBOE Indices and the Denali Exchange Data Feed for the CME Group.
When you have both Exchange Data Feeds active in a month, we will credit your account by $12.00 USD to help offset the cost of using both feeds.
