Date/Time: Sat, 08 Feb 2025 05:05:19 +0000
Spreadsheet Bid(J13)/Ask(J15) Not Updating in v2123
View Count: 649
[2020-06-17 13:46:58] |
User884307 - Posts: 173 |
Hi In Spreadsheet cells J13 & J15 are not updating in any configuration of replay mode. In live market there is no problem Updated to version 2124 but noticed it in 2123 (not sure if prior versions are effected ) thanks |
[2020-06-18 23:04:11] |
You are referring to the bid size and ask size cells. These will always remain at 1 during a replay. We do not want to go into further technical details, but that is just how they are going to be. Specifically refer to: Replaying Charts: Bid and Ask Prices During Replay You can use this study to access the market depth data which will give you the actual quote data sizes: Depth of Market Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-18 23:27:45
[2020-06-26 22:10:12] |
thanks for reply.....that is strange because these cells always did update until recently as I have calculation based upon them , then when I updated SC the just appeared as 1?
