Date/Time: Fri, 07 Feb 2025 21:26:05 +0000
Bar Close Time / working ?
View Count: 543
[2020-06-17 09:28:38] |
TedMar - Posts: 190 |
Hi, realy simple quest: i.e open Chart 5m time frame check u local clock if local clock is 12:23 then Bar (5m) @12:20 worked I would like change this like other Software. i need Bar Close at 12:20 ,and Bar 12:25 working. How? |
[2020-06-17 11:10:33] |
We can only refer you to this section: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
