Date/Time: Sat, 04 Jul 2026 20:38:07 +0000
Session Times
View Count: 710
[2020-06-17 07:08:49]
User907968 - Posts: 873
v2123
Session times are not being applied correctly when opening new charts, see attached image.
This is observed when performing the following actions:
1) Opening a new chart via 'Find Symbol' -> 'Open Intraday Chart'
2) Opening a new chart programatically using sc.OpenChartOrGetChartReference()
The session times are applied correctly when performing the following actions:
1) 'Chart Settings' -> 'Apply Global Symbol Settings'
2) 'Find Symbol' -> 'Change Chart Symbol'
My configuration is unchanged since v2109, in which the session times are applied correctly upon opening a new chart.
Please advise if there is some new setting that needs to be changed, thanks.
imagesession_times.png / V - Attached On 2020-06-17 06:52:28 UTC - Size: 215.62 KB - 309 views
[2020-06-17 11:28:06]
We are looking into this.
[2020-06-17 11:59:52]
Ok, thanks.
If it is any help, v2119 seems to behave correctly.
[2020-06-17 12:01:45]
This is resolved in version 2124 which we are putting out in about 20 minutes.
