Date/Time: Fri, 07 Feb 2025 22:58:19 +0000
Access to real-time CBOT data
View Count: 879
[2020-06-17 04:56:22] |
tommartin321 - Posts: 74 |
Hello, My account currently has access to CME real-time futures data using your SC Data - All Services data. What I want to do is add real-time CBOT to my account so I can have access to the ZB and ZN futures. However, if I understand everything correctly, the only way I can get CBOT futures data is by using your Denali Exchange Data Feed. Is this correct? Is there anyway I can get CBOT just by keeping my SC Data - All Services? Thanks, Tom |
[2020-06-17 11:20:54] |
The Denali Exchange Data Feed does support the SC Data - All Services setting in Sierra Chart. Denali data feed documentation: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-06-17 19:23:40] |
That's not what I was asking. Is there a way from me to get access the real-time CBOT futures data without opening a brokerage account? |
[2020-06-17 19:57:02] |
Yes but you do have to pay the CBOT professional exchange fee which is 110 USD a month. Set up instructions are here: Denali Exchange Data Feed You can also use this easy solution to reduce the cost of exchange fees assuming you are a nonprofessional : Easy Solution to CME Funded Trading Account Requirement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-06-18 04:10:46
[2020-06-18 00:24:17] |
Great, thank you.
