Date/Time: Fri, 07 Feb 2025 21:31:40 +0000
How to adjust the height of indicator window
View Count: 1271
[2020-06-17 04:10:09] |
User603146 - Posts: 2 |
Dear Sir I added the studies of numbers Bars Calculated Values indictor and it appears to some data column as you can see from the captured screen. I just can't find the way to control the height of the column. Could you please tell me which setting I could adjust to control it? Thanks Jack |
[2020-06-17 11:21:41] |
Refer to: Working With Charts: Chart Window and Regions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
